Auto Doc's
 - Sep 7, 2024
- Threads
 - 19
 - 1,747
Hello folks,
EDIT: This turned out to be a 2nd help request because the original one did not show up when I searched earlier.
This site is clunky at best.
I have an early serial number JD 757 that I am working on for a customer, I need a wiring diagram for it. The only one I could locate online is blurry and incomplete. Specifically, I am dealing with a red square block, plug in harness diode that is usually found on most large JD riders and zero turn mowers. The one on this mower tests bad with a multimeter.
I am not a fan of jumping safety switches and only do so for testing purposes. Currently I have the seat switch jumped and the diode removed so I can operate the mower.
