hey everyone, I have a 1987 john deere 214 with a issue that I cant seem to get an answer to, I had a spark problem, changing everything from the ignition switch, to the points, ok, now the issue I have now, is the little push rod that pushes the points open will not move when the engine cranks. I pulled the rod out and it moves freely, is there a reason why it wont move when cranking ???
