frankiebee
- Apr 29, 2012
- 0
- 3
Hi guys, I am having trouble with my john deere 185 hydro. I am fortunite to own a deere, I bought a house last year and my father gave me his lawn tractor. As far as I remeber when you turn the key it always "clunked and clicked" a few times then it would fire. From little research I've found that that clunking sound is from a failing starter solenoid.
I changed that, I also left my battery hooked up all winter that was dead and wouldn't hold a charge. So I bought a new battery, Keep in mind I had this started after I put in the solenoid, by putting a BOOST Charger on it I am guessing about 15-20 Volts. Now I have a new battery and It acts like a dead battery, Lights dim when I turn the key, you bearly hear anything.
I tryed to jump it off the solenoid and its sparking like hell and it sound like somthing in spinning really fast. Could I have a bad starter?
My battery has 13 volts, the starter solenoid has 12 volts I checked it with a volt meter. Im sure if I put the boost charger on it will fire up, but I dont want to do that to my brand new battery. Any Suggestions, I am tempted to go buy a new Deere, but That wouldn't make my girl very happy.
Any comments are welcome. Thank You and I appreciate it.
cleaned the cable connections with baking soda and a wire brush? do you get 13 volts with the engine running? if not, there is a charging problem.
