Hey Fellers. Here's my problem. I was mowing yesterday and the mower just stopped dead. Briggs twin v-tek. good oil level and fuel. I turned the switch on and off and it was though the battery had been disconnected. I found the 20 map fuse was blown and replaced it. I don't have a wiring schematic so don't know what it fuses but after replacing it the starter tries to turn but the fly wheel willl not spin. It just locks up. I have dropped the mower deck and disconnected those belts. I've checked for blockages like gumballs which might jamb the drive pulleys and belts. The flywheel will not turn by hand. Mower is 4-5 years old with 180 hours
and well serviced by the dealer. I'm stumped. Any hints you might suggest will be greatly appreciated. I'm going to search the forum to see if anyone else has had the same problem but wanted to throw this out before I started looking here
