awesomedad
I have an older JD 116 and I cannot get it to charge the battery or find any usefull information on how the stator is supposed to be wired up. Right now if I hook up the diode assembly to the solenoid it doesn't do anything or it will start heating up quickly and still not charge the battery. I have checked the voltage coming from the stator and I am getting 28 volts. By the amount of voltage I should need a regulator? Right? But the other issue is that I am only the second owner of this tractor and the other was my dad he bought it new and it's never had a regulator. I just don't understand how to wire the darn thing in so that I can charge the battery while its running. Please help
