Could be a lot of things. Let's start with the easy ones first. All of the items I am going to ask you to do may sound stupid, but if we don't go through the entire list, the one we skip will be the problem. First we suspect that every part is bad until we test it good. For all steps make sure that the parking brake has been set. 1. Check the battery voltage, should be at least 12.5V. 2. Check every connection, making sure they bare clean and tight. 3. Short across the two large terminals on the solenoid with a large screwdriver or pliers with the key switch in the run position. It should turn over and start. 4. Take a wire and go from the + terminal of the battery, to the small terminal on the solenoid, with the key switch on. It should turn over and start. 5. With a test light, check to see if you have power at the B terminal on the key switch. 6. Turn the key switch to the start position and with a test light check to see if you have power on the small terminal of the solenoid. 7. Remove the solenoid and clean the base of the solenoid and the chassis wherebit bolts to, to make sure it is grounded good. This is the sequence which I have given to my students for years. Many people use a different order, but using this makes you double check yourself, which you must do when working with electricity. Have patience and take your time, it's easy to miss something. Let us know what happens, and we will be able to tell you how to proceed.
