John Deer Stander 19hp Kawaski
chrisvon
My John Deee stander with a 19hp Kawasaki shuts down while in operation, Ive already change coil packs, and plugs. What would be the possible Cause? any help would b very helpful.
briggs
Its a john Deere ....LOL...Just kidding please post model number then we can look it up and see what going on ...could be a carb issue is it over heating hows the oil lots of things could go wrong how long will it run for need a little more info
chrisvon
647 a, oil is ok, not over heating, it will run for about 10mins then shut down, aftaer a few minutes, it will start up run again for a lil bit then shuts down
briggs
loosen the gas cap and see if that helps ..The vent in the top could be plugged up ...If that's not the issue ...I would clean the carb I use high test gas and sea foam and blow them out with compressed air change the fuel filter and the fuel might have water in it seen it happen .. ....Let us know how u make out
chrisvon
Ive change the fuel filter, same prob, i hve one of the wire going to the starter, (i guess its the ground wire) disconnected wen running, but when i connect it, the motor shuts off.
briggs
loosen the gas cap might be getting a vapor lock
reynoldston
First thing to do is when it quits running is find out what it is lacking. Fuel, spark, or compression??? Don't just start changing parts.
