Tuff torq hydraulic rearend not servised by jd. Non serviceable they say. New one is an half what I pai
d for this POS tractor $700. I contacted tuff torq and put in new center case kit, motor, and pump! Still no go, can stop axles with hand.
Main drive pulleys new, new belt, tension on output shaft seems correct. The gear release bar is in the right position. Cotter keys are on axles. Any ideas are appreciated before I take my 12 gauge to it! Thanks.......
Bill
Bill
