I have a JD x300 mower with a 42" mulching deck. The deck does not cut evenly since I have the mower serviced. When I pull the deck and flip it over, the blades are 1/4 inch difference in height. This is about the same as the un-level cutting on the yard. There is no play in any of the blade pulley shafts. Could they have misplaced a spacer or is this normal height diffrential
