Sudsy 49 said:My JD STX 38 was running fine until one day I started it up and white smoke started pouring out the exhaust. Any thoughts out there?
Yes, I shut off because I did not want to piss off my neighbors.
Hey jddoc,
Why waste my time replacing the head gasket until I diagnose the real problem. Seems like the carb needle valve stuck and flooded the cylinder and crankcase with gas.:smile:
When this flat top Kohler engine starts smoking suddenly the head gasket is blown between the cylinder bore and the pushrod galley. On the intake stroke oil is pulled into the cylinder, causing excessive exaust smoke. This is a common problem. The engine will run with very little change except smoke
