JonnyBlaze
Ive read up on this and I know its either ignition switch, pto switch, rio switch, solenoid or brake switch. I ordered a new solenoid and ignition switch. Brake switch is still intact at the mount.
New battery. Runs great if I jump the solenoid. They ignition switch does weird things depending on position its in while its running. If I have it in one position and press the reverse pedal, the mower deck starts moving then it stalls. Also, pto switch only turns on the deck when in a different key position.
Headlights dont work at all.
Fuse near solenoid is good. No power to starter side of solenoid. No power to purple wire on solenoid. No power coming out other end of fuse.
Also found a stray black wire. Not sure where it goes. Says P.E.D on the connector.
