JD L120 Briggs and Stratton repair question
gregfrey
Hi all;
Brand new to the forum, pleased to meet you all. Previously, I inadvertently placed this post in the wrong place on the forum.
I have a 15 yr old JD L120 with a Briggs and Stratton Intek V Twin. The governor is shot. Unfortunately, the rod is broken. Is it possible to replace? Or, since the rod is 'built in' to the block, do I need to replace the block?
Thanks
Greg Frey
Havent been here long either so welcome, lots of advice at the Briggs forum you might have better luck there
Yes, you can replace the governor rod. Give us all the engine numbers and we will get you a manual to help you out.
Thanks for the reply! I had a local repair shop open the block. The governor shaft is not broken. A different shaft broke, whose base is embedded in (does not pass thru) the block wall. He tried to heat the aluminum block to get the shaft out, but no luck. I'm considering purchasing a short block.
Best
Greg Frey
