JD L111 is making a whining noise
Huskergasman
I pulled them off today an the smaller one definitely turns harder than the larger one. Called Prairieland JD here in Wichita, they have them both. I will pick them up tomorrow and put them I and let you all know. Thanks again, Rivets!
I would change the drive belt at the same time. May have been damaged by a bad pulley. Mig,hr just as well change it while your under there. Just a suggestion.
Huskergasman
Problem solved, runs smooth as butter! Replaced both idler pulleys. Rivets, you rock!
Glad to hear it, at least something went right this weekend.
