JD L100 engine swap
cheathkl
Hello everyone,
I have a JD L100 that came with a 17 HP B&S Intek engine. I was wondering if a recently purchased 18 HP B&S Twin Power engine would work in my L100?
Thanks in advance for any advice,
Kyle
Yes it will bolt right up.
And the pulley will work.
Only thing you might have to do is splice a wire or two
(( racing is the only sport that you need two balls ))
Awesome! Thank you very much. I took a risk last night not knowing if this engine would work.
Hello everyone it's me again,
I have JD L100A 5speed riding lawnmower. I purchased a 18hp Twin Power Briggs (model # 422707-1522-01). It bolted right in. One problem though it seems like it is not getting any gas. I blew thru the gas filter and hoses and all seem to be functioning. I'm guessing it's the pump but I opened that up and to me it looks good. Maybe the floats are bad. Any advice would be greatly appreciated.
Thanks,
Kyle
