EngineMan
- Jun 12, 2012
- 2,275
Thanks again Engine Man!
I could start the engine yesterday.... for the first time.
I primed 2 or 3 times (this rubber ball pumping some drops of gas into the carb) and it started easily.
But the engine didn't seem to be stable...rpm was not constant and (at idle but also under higher rpm) The engine was 'surging'..rpm going up and down.
Another question: Are there new 'tires' available for the mower...in order to climb better. My tires have almost no profile left and the mover has a hard time to climb my New England lawns...
Best, Martin
If the carb has mixing screws then they need to be adjusted, which should help with the surging, if no adjustments then the carb needs a clean out, if all is well with the governor and rods, I can't help you out with the question on the tires has I don't live in the USA.
