Had a fire a few weeks back with my JD E150 (with only 47 hours on it) . I was trying to mulch leaves (on an extremely dry day). Not sure exactly what happened but leaves that were under the deck evidently caught fire. (Perhaps I knicked a rock that caused a spark. ) In any case I grabbed a fire extinguisher that knocked down the flames and used water to put it out, but not before flattening the front tires and damaging some plastic and melting the discharge chute. I think the engine and drive train escaped damage. It will not start and I'm guessing the wiring harness may be damaged. I believe the main harness is $125 and looks like no fun to mess with. Any suggestions?
