I was pulling a small trailer up a hill the other day when I noticed a rattle started coming from under the machine, it a JD D155 with ~ 30 hours on it. It doesn't have the mower deck mounted but the rattle is coming from the PTO clutch, there is a notch that sits on a arm and the clutch is vibrating on the arm. I pulled the clutch off and all the bearings seem to be good but I can't for the life of me figure out what is causing it to vibrate so bad. Its definitely not right though.
Thank in advance!
Thank in advance!
