Engine Jd 826 snowblower
Mwh0428
I have a jd 826 snowblower and a family friend rebuilt the carb on it it has a tecumseh h80 snow king but it will only run on full to 3/4 choke. dose anybody know what's wrong?
KennyV
Look back in the carb... float level or something is causing it to be too lean,... May be an air leak between the carb and the intake port... :smile:KennyV
Mwh0428
Dose anybody know were I could get parts for it other than eBay
Mwh0428
Could it be the the valves? And if so how do I check them. I ran it last night so my bro could go to work and I had a rough idle unless under a load and I had a blue flame coming out of the muffler. but it runs like a top under load.
sawman024
Hello,I would say the carb main jet is still partially clogged.If it starts and will run on choke the valves are good.See if this info helps any.Go to the 4th page of the 7.
  • 3-11 hp 4cycle L head engines carb.pdf
