JD 757 ZTRAK hydraulic oil tank replacement help
hootowl23
I am a private owner of a used 757 mower. The hydraulic oil tank on my 757 has a leak and must be replaced. I am having trouble figuring out what needs to be removed to get the tank out. I have removed the tank mounting bolts, the gas tank, the steering mechanism, and disconnected the hoses to the tank. It seems the tank would come out from under the seat if the fan on the hydraulic pump and the cage around it were removed so that the tank could moved back and then lifted out. However, the tank position prevents access to the fan cage mounting hardware. Any help would be greatly appreciated.
