JD 757 Kawasaki FH721D Block/Crankcase
Chitreano
I am looking for a Kawasaki FH721 AS04 block. I was replacing the oil cooler gasket and overtightened the bold and busted the block. Not sure if it could be welded.
The block I need is JD Part # MIA 11106. The Kawasaki # is 49120-6163, 6137, or 6135. The FH721 AS04 number is proprietary to Deere and all the information I can gather points to the FH721 AS01 and AS05 being the same block. It has a horizontal shaft. If you have one or know of one please let me know. There are conversion kits & engines available but there is noting wrong with the engine except for the oil leaks I was attempting to fix.
Thanks in advance.
49120-6163 is for the AS04. The following is the two crankcase with 6137 being the most common of the two used. Both number are superseding to the 49120-6163. My distributor is flagging it as NLA per Kawasaki.
AR = As Required
