weprknarly
- Jul 7, 2011
- 2
looking at buying a 300 series lawn mower.. i think the hyro might be going out. i set the throtle at about 3/4. when i moved the lever forward or reverse, the tractor would not move until the lever was moved at least and inch either way. if i moved it about half way forward, the tractor would start moving.. then increase speed slowly.. at one setting the tractor would move a long at a good clip, but studder. the yard had a short hill to try it on. as the mower went up the hill, the motor did not seem to slow down, but the tractor did.... it sounds like this mower has set or rairly been used for the last 10 + years.. any thoughts or ideas ???
