Black Bart
- May 4, 2011
- 550
An update to this thread; I found the small heat shield located behind the carb was missing. I am assuming this could be the source of my problem, allowing the heat from the muffler to get to the carb vaporizing the fuel when it gets too hot?/ Thanks to Bart, I never would have noticed this without his mention. Hopefully this resolves my issue. Now, finding a heat shield that will work with this specific application, any suggestions?
I did locate what is called "thermaflect shield" a 5" x 7" pad that might work. Thanks again!
Check with local JD dealer it should not be too expensive.
Just for added measure you could add the thermal piece under the heat shield.
My son in-law has a 265 I'm going to drive out to his farm and take a look at his and see if it has the same shield as my 180.
If it is the same and I think it probably is then you may find an old mower that has been scrapped and get the shield from it.
Mine is bolted to the frame and slopes upward over the muffler and directs air flow down and away from the carb.
