Repairs JD 265 engine issue
jimoster
I have a John deere model 265 tractor that when I start to drive it and put the engine under a bit of stress the engine falters and will stall out. i can start it up again, but will continue to do the same thing. Any suggestions for repairs
KennyV
WELCOME to LMF...
Either a restriction in the line/filter Or in the carb itself...
What engine is on your JD?
When it starts to drop off, before it dies, If you Choke it will it respond?
:smile:KennyV
