Export thread
JD 185 wont start
#1
J
JD185
Hi, I have a John Deere 185 with a single cylinder 17 hp FC540V-CS00 engine. It was running fine, no issues at all. Went to start it up, and it wont start. Cranks and cranks, tries to start, but wont. Actually, I did get it going, and it ran great like normal. Shut it off to try to restart, and it wont restart again. This is why I am unsure of what could be wrong, knowing that it runs fine once started, but its the starting issue. It is getting visible spark via plug removed and resting against engine block, but I don't know if it is sufficient spark to start it? Fuel is fresh and it is getting fuel to the carb, and plug is wet, but not soaked. I put in a new plug (NGKBPR5ES) I have since removed the plug to inspect it after attempting to start, and it has some black carbon deposits on it. I tried a little starting fluid as well. I have cranked and cranked, as it seems like it is so close to starting,with random fires, but it wont. I can hear the combustion, and see obvious signs of smoke coming from the exhaust during this time. After searching the internet for this problem, I am more confused now then initially. Appears as though this is not an uncommon problem with this mower. Seems that Coil and/or Ignitor keep coming up as the most common fixes. Would a bad coil still provide enough spark such that it runs fine, but make it almost impossible to start? I also found information about a Starter Improvement Relay kit that seemed to help a lot of guys. Does anyone know if this kit would increase the speed of the starter, as it kind of seems like the flywheel may not be spinning fast enough to start the engine. Or is this kit solely to make sure the starter engages the flywheel? Any suggestions, questions, or did I miss anything in my rambling?
#2
Carscw
Carscw
Spinning the engine faster is not going to fix your problem.
I would make sure the choke is working the way it should.
Check compression. You can borrow a tester from most parts stores.
If it was the coil it would not run fine once you get it started.
When it starts does it have all the power it should with the blades on?
#3
EngineMan
EngineMan
Check all the safety switchers the electrical schematic below should give you some idea what to looking out for, if you not understand a schematic or wiring you will be better off taken it into the shop.
J
JD185
1. ok, thanks
2. I have removed the air cleaner and been manually moving the choke and throttle, When I feather the throttle, that's when it most sounds like it will start. I am familiar with non electrical small engine carbs, but not necessarily this particular one. There is a wire connected to the bottom of it...
3. I will check compression, but it could take a while for me to get. It ran perfect once started, and with the blades engaged as well. So I guess I was assuming the compression was good.
#5
J
JD185
I understand the schematics, but not fully confident on being able to check every one. I will try to enlist the help of someone a little more knowledgable about how to test each switch. I have a volt meter, but not confident with it. I would love to take it to a shop, but do not want to invest what could be several hundred dollars when I can just buy a used working mower for a similar price.
This gets me thinking though. I used to be able to move the mower in neutral fairly easily, but moving it around since it stopped starting has become a chore, such like the transmission is still engaged... I will check into this as my next step. Would the transmission being engaged make it sound like it wants to start, and even fire, but not fully start? Please anyone with a thought- comment
#6
EngineMan
EngineMan
Is it fitted with a fuel solenoid, if so check it out make sure you hear a click when you turn key to run, because you say you are getting spark.
#7
J
JD185
I disconnected the fuel line past the fuel pump, and it pumps when I turn the key. I tried disconnecting the wire that is attached to the bottom of the carb too, no change. but yes, appears to be getting fuel to the cylinder...
#8
EngineMan
EngineMan
If its getting fuel to the cylinder, then recheck the spark.
#9
J
JD185
It has spark, but im not sure if its enough. Would this make sense, that it is getting spark, enough to run "normal" If it can get started, but has a very difficult time starting? The coil is old and rusty, so I am trying to decide if I should even bother buying a spark tester, or just buy the coil, since it seems like this or the ignitor is the most common part to fail on this engine, according to everything im reading anyways.
#10
J
JD185
Attempt to find the coil that is... discontinued. Looking for part # 21121-2059. Every website I find that says they have one, does not. I have a call into the local John deere dealer, will see what they say, or perhaps theres a replacement part number hopefully.
#11
EngineMan
EngineMan
Rust on the coil should not make much difference, is it the Kawasaki FC540V engine. It maybe the control unit and not the coil...! and I wouldn't have thought that 1986 - 1990 was too old to be able to get hold of parts, you should be able to find a after market part somewhere.
#12
J
JD185
Yes, that's the engine. I called the dealer, but naturally he wouldn't give me the part #, its top secret/classified, such that I have to buy theirs, that they do have in stock... I too thought there would/should be an aftermarket part for it, but cross referencing it is difficult. I called another non john deere dealership and they told me that john deere had Kawasaki build this engine "special" for them, so Im sure there are aftermarket parts out there for basically the same engine, but without trial and error, could be difficult. I have No intentions of buying a few aftermarket coils that "should" work. So if I think its the coil, its $67 from the John deere dealer. wish I could just try it and see, but that's a $$$ gamble without knowing for sure, but Im considering it.
By control unit, are you referring to the black board under the dash? The reason I am so confused is that I did get it started , and it ran fine since all of this non starting issue began. and it turns over and basically starts, but doesn't, if that makes sense. and I really appreciate your input, Thanks! Not giving up yet
#13
Carscw
Carscw
Try choking the carb by holding your hand over the opening.
#14
J
JD185
So I ended up buying the new coil from the dealer. A gamble at $67+tax. Got it home and installed it, sounded no different. Let it set for a few more minutes, tried it again, and Bam, she started right up!!! Not to be fooled, I let it run for a while, re adjusted all of the carb screws that I had messed with, and shut her down. Big test was to see if it would restart, as this occurrence has happened before, shut it off, then no restart. This time, it restarted right up. Too late to mow my much overgrown lawn covered with leaves now, but assuming it starts again tomorrow, I hope the problem is solved! So at this point, I am just guessing that the spark was present, but just not strong enough to get it started, but if by chance it did start, was fine. and now my next tool on the list is going to be a spark tester! Thanks to everyone for all the feedback, and to anyone else that might have a similar issue, perhaps this may help you as well.
#15
Carscw
Carscw
Glad you got it going its nice to get lucky once in awhile.
#16
J
JD185
No kidding, and thanks!
#17
EngineMan
EngineMan
Very happy for you, good to know you didn't waste the $67+tax on the coil...!:thumbsup:
#18
J
JD185
Believe me, after it didn't start "instantly", my head just sank...I guess I got to the point of where it didn't seem like there was any other feasible problems that I could think of, and decided to try this, as it made the most sense. and Thanks, me too. Thanks for your help!
#19
J
JD185
Ok, so I had a little difficult time starting it up today, but am thinking that perhaps that was because the battery was not fully charged from obvious reasons. Once started, it ran good, and I got a few acres mowed with it. During the course of this, 2 times, it just flat cut out and shut down. It would immediately fire back up though, no issues. There was no sputtering or anything, so I am fairly confident its not a fuel issue, but very likely one of the safety switches. I rechecked the oil, that was fine, and the oil light didn't light up. Im just curious if this sounds like anything other then the seat safety switch? I will check it when I get time, but my daughters were getting cold, and I wasn't too worried about it, because it did start right back up, just a minor inconvenience. Just figured I would throw this out there to see if there is any other recommendations to check when I do get time to go mess with it again...
#20
EngineMan
EngineMan
Yes check and clean all safety switches, that would be my next step..! and any wiring connections.
