JD 180
vshaver
Whats the secret to getting the steering apart underneath the mower in order to change the bad drive belt older model? Thank you:licking:
Catherine
LawnWorld Support
Staff member
:welcome:
I'm going to move your thread over to our John Deere section. Someone over there should know.
vshaver
The secret is draining the fuel and removing the battery then remove the deck ( JD call it mower ) from the tractor.
Now stand it up vertical so you can see everything and work comfortably
Now follow the instruction in this file
I will go see it physically tomorrow and report back thank you
and what i forgot is stand it on its bum, not the nose or all the oil will drain into the carb & cylinder causing more grief.
