I tried putting the brand new coil on upside down with no difference.....the spark plug wire had to be rerouted but reached the plug.....the kill wire had to be jumped to reach. Also tried a good used coil and trigger by themselves and in all combos with the newly purchased OEM ones. I’ve marked where the intake and exhaust valve opens and closes on the flywheel and where the decompressor blimps.....all on the engine that doesn’t start. Next I want to mark the same thing on the good used engine once I get all the “donor” parts back on....then compare the marks. Too cold to mess around too much here at home.....27* high with no garage heat!
