Hello Everyone,
Great pre spring day here in Mcdonough, GA. I hope all are as good or at least comfortable today. Bad time for me right now. I am having difficulty with my Snapper rider, and I pull out my John Deere to change the tank which had split. JD had been sitting up for almost three years with no use. Would start it every once and a while and started fine. I changed the tank, loosening the seat spring bolts, the six bolts under the cowling and lifted the back enough to put the new tank on. Did not disconnect any wires except the battery, which I pulled out to lift cowl. Tank went in with no hitch and proceeded to put together mower. The only thing that I had a little problem with was reinserting bolts in the cowl (6), I had to put a little down pressure on cowl to get bolts to line up. Everything was tightened down and before I put the battery back in, I pressure washed the inside of the cowl and around the engine, put the battery back in, check the charge before installing, and when I went to start, I turned the key, 1st the lights came on, I heard a click, went to start, and nothing at all. No engine turn over, nothing. Check the 20 amp fuse, it was good, re checked the battery, showed full charge right away, tried jump start with charger, nothing. I am not electrically prepped here so any help will be appreciated. My first question is could I have disconnected a wire under the base when lifted to change gas tank. Is there a way to start the motor without the key, or is there another fuse somewhere that could cause this problem.
Again, any help will be appreciated. I have no way right now to get the mower up on my truck to take it in to be checked.
Thanks,
Xman
Thanks,
Xman
