Hi Kdeerman
I have a Jazee and we like it it's 48 inch cut with a 20 hp Briggs and strattion ELS engine. Ares has the joy stick and they are very touchy just a little movement and they will move, so you might want to try a test run before you buy one. If the grass is a little wet the tires will spin very easy so you have to be carefull. I think the one with two handles are better .The Jazee i have is solid frame and the Jazee one has a movement on the front so when you go down a hill or sloop it will tilt some witch i think is better. And i think there is a little better hydro transmission in the Jazee pro we have not had any problem with ours. We have about 135 hours on this unit. One things that is really nice is that you can flip the mower deck up and clean it and sharpen the blades pretty easy and fast. You can mow very fast with it really moves if you push the joy stick all the way forward.Over all it's good. If you look in my pictures there is a picture of it its the red one.:licking:
