jacobsen 2 cycles
gary lee
I looking for information about 2 cycle jacobsens like are the engines made by tecumsh and did the connecting rod use needle bearing. thank you
Do you have a model number for either the mower or the engine?
Please post a photo of the mower -- and welcome to the forum. :welcome:
I haven't found much based on that model number -- which I think applies to the engine -- right?
Is this a "greens mower" (reel as opposed to rotary)?
Jacobsen is still one of the leaders in that market segment, but I think the mowers are now mostly Honda-powered.
Some pictures might help ID your mower.
I believe the 984h was built by fuji.jacobsen built thier own 2 stroke until the castings wore out then started using these engines.
Jacobsen made their own 2 cycles, they used Briggs and Stratton for their 4 cycles. The 321 engine did have needle bearings in the connecting rod. Supposedly the 501 engine was a heavy duty version of the 321, but I'm not sure what was different.
