- Sep 7, 2024
- 3,489
The differential should be an inch below the fill hole to allow for heat expansion of the fluid. That is how I fill most manual transmissions.
As for ATF. Just regular old type "A" or type "F" should do just fine. A basic cheap hydraulic fluid will work as well. Nothing with a bunch of additives.
The ATF should be filled in a similar manner. Knowing the exact amount for a machine this old will be very hard to find.
