Gord Baker
- Aug 21, 2018
- 1
- 484
Remove and clean all Battery and starter Cable connections. Use a file/wire brush etc.
With Car or other 12VDC source OFF, connect + to Starter and - to Clean solid surface on engine like mounting bolts.
Work backwards from there....other side of solenoid etc.
NEVER TRY TO BOOST A SMALL ENGINE FROM A VEHICLE WITH ENGINE RUNNING. YOU MAY DESTROY THE CHARGING STATOR ON THE ITEM.
