mike coulter
- Apr 10, 2016
- 57
put a new battery on a MTD rider mower MTD13AM675G062. had to charge it overnight and when I tried cranking it, the motor wouldn't:2cents::confused3::confused3: even spin. it just moved. looked the charger at its back down in the yellow. could the ignition switch be faulty causing it not to charge fully and draining the battery.?
