neighborbill
Yesterday I was going to start up my cutter. Turned the key and every thing went dead. No lights, nothing. I thought that a fuse went for what ever reason. Checked all fuses. Wasn't the problem. I open up the control panel to look inside. For the heck of it, I pulled the connector to the key switch off and put it back on. To my surprise, the cutter came alive when I turned the key. Now I had lights (oil and batt, glow plug) but no start up when I went to the spring loaded switch. Nothing.
I can start the diesel by jumping the starter and turning the key switch to the run position. But, then the oil light stays on. While is was running I tried engaging the blades. Pulled the switch and the cutter went dead.
This machine was purchased last Nov 2022. It has about 21 hours on it .
Obviously, it should be under warranty and I'll need to take it in. I was going to try and fix myself thinking that it is probably the key switch at fault. But with the oil light remaining on that's a whole new problem. Don't want to take any chance on low oil pressure and screwing up my Diesel.
I still would like to know what heck is going on. This thing is brand new.
Some sites say that the oil filter might be plugged or low on oil. It isn't low and how could the oil filter get plugged with only 21 hours on it.
Last but not least, I believe that trying the electric clutch for the cutters kills the machine because the oil switch is telling something called "Shut Down Module" to operate. Doing it's job.
I'm open to comments, questions, and or answers
I just don't understand what happened. Key switch bad? Oil sender bad? Shut down module? Find that hard to believe as the problems.
