is1500z
Jayraud
My is1500z ferris mower just shut down on me in the middle of mowing my yard. It blew the 20amp fuse on the ignition. I replaced the fuse. The engine will start up and run now but, when i release the parking brake, rh or lh neutral switch, it dies. Ive checked and ohm’d all wires. The switches test good with my meter. Any help would be appreciated. Thanks
Nod
I had a lot of odd problems with the same mower and my safety switches were the problem. My pto switch was even bad. Hope you work it out.
Jayraud
I bought a pto switch along with a neutral switch and parking brake switch. Hopefully this resolves the issue. I need to mow!lol
