Is this wire connected correctly?
The old VR had correct connectors. WD-40 was squirted in each connection before replacing the VR. I believe they are solid connections.
WD-40 gums up in six months time. Turns into a sticky mess.
Better sprays like contact cleaners and enhancers one could use to spray on.
Another tip is use marine grade heat shrink that has adhesive inside it. It ooozes out the end when hit with a heat gun. This weather seals each connection where it is used. Keeps all the water, humidity. corrosion and dirt out of the connection.
I gotta get some of that marine grade. I didn't know about that, sounds great. Thanks!
