I have a Lawn Boy Gold Series, Model # 10515, Serial # 5904247, with a 4.5 HP commercial engine. The last couple times I used it, I could hear the engine getting tight, then it would stop. After it cooled, maybe the next day or so, it would restart and run, but again tighten up. Finally, it quit. The fuel mixture is OK and I use the same fuel in other 2 cycle engines with no issues.
After taking it apart, realized the rod broke near the crank.
Couple questions:
1.) What would cause this to get tight and eventually break the connecting rod?
2.) Is this a "F" Series engine? I have been looking for parts and need to be sure the engine type.
3.) Any suggestions as to where to look for parts, or a replacement engine?
Thanks
Couple questions:
Thanks
