on my JD X485?
O overdriv Member Joined May 15, 2019 Threads 8 Messages 13 Jul 14, 2021 / IS there an oil filter for the rear axle #1 on my JD X485?
StarTech Lawn Royalty Top Poster Of Month Joined Feb 19, 2020 Threads 118 Messages 12,664 Jul 14, 2021 / IS there an oil filter for the rear axle #2
M MParr Lawn Addict Joined Jul 2, 2021 Threads 9 Messages 1,972 Jul 14, 2021 / IS there an oil filter for the rear axle #3 @StarTech gave you the part number. To locate the filter, look under the tractor at the front centerline of the axle.
O overdriv Member Joined May 15, 2019 Threads 8 Messages 13 Jul 14, 2021 / IS there an oil filter for the rear axle #4 Thank you.
M MParr Lawn Addict Joined Jul 2, 2021 Threads 9 Messages 1,972 Jul 14, 2021 / IS there an oil filter for the rear axle #5 overdriv said: Thank you. Click to expand... Refer to your operators manual for the correct procedure, oil type and refill capacity. You will have to remove the mower deck before attempting.
O overdriv Member Joined May 15, 2019 Threads 8 Messages 13 Jul 19, 2021 / IS there an oil filter for the rear axle #6 Found it, yes on deck removal. Thanks.
