Hi,
I have been having problems with my petrol mower. It seems to be running slowly and unevenly chugging like it is about to stall all the time. From googling one suggestions of the cause of the problem is that the air filter (marked in attached photo ,LawnMower.png, with the red arrow) may be clogged with oil. I opened the filter to inspect it and it does indeed seem to have a lot of oil in it. Before buying a replacement filter I would like to be sure that this is the only problem. So I'm wondering if it is okay to run the mower with the sponge-like insert (see AirFilter(1).jpg attached) in the air-filter removed completely. I assume this insert is to filter out various airborne particles which would clog up the motor over time but that running without it for a short time just to test shouldn't be a problem ? I'm not sure if this is safe though, I know next to nothing about petrol motors. I assume running it without the insert might result in a larger airflow into the engine, could this cause it to malfunction or damage it ? Or is this a safe enough test ?
Thanks,
Usjes.
Thanks,
Usjes.
