Is it better to run out of gas periodically vs topping off the tank before each use?
I'm asking this about lawnmower engines here, but I suppose this also applies to snowblower engines too, and any other gas powered machine.
I usually top off my tank before each use, unless its late in the season and I'm explicitly trying to run the machine down on gas. And I keep my gas clean, and i drain the gas and winterize at the end of the season, and I put a little seafoam in all my small engine gas, so everything seems fine.
But I see so many youtube videos where they drain the carb or the tank and theres so much dirt or water in the fuel. It seems like it would be kind of hard to get water in a lawnmower engine. You'd have to be gassing up in the rain, but most people aren't going to be using their lawnmower in the rain in the first place. But with snowblowers, its very common to have to gas up while its still flurrying out. Or to just have snow everywhere so when you take the cap off, a little falls in.
So if you run it out of gas, the engine is going to suck in at least the water, if not some of the micro-dirt too and 'burn' it up in the engine and sent it out the tailpipe, preventing it from building up in the fuel system.
Is this sound reasoning? Or are there other factors that make this moot? I almost never do this, but it would be easy to start. Especially with a lawnmower. It would be a little more of a hassle to do it with a snowblower given how big and heavy they are (and mine has tracks so you can't push it, you can only drive it when its running).
I wonder what other people's thoughts are on this?
The water in the tank comes from condensation in the fuel container and the Ethanol process.
I never totally empty the fuel container, always shut off fuel and run engines dry and drain Float Bowl for Winter. That Ethanol (now 15%) can really seize up a Needle valve. Everyone has a different opinion.
That is mine. I am a 'first pull' guy. A splash of Sea Foam in a nearly empty tank doesn't hurt. Run it, let it sit for a couple days and run again.
Ethanol Free gas is not available in Canada thanks to Trudoo and his Lieberals.
The cheap fuel now has 15% (e15) ETHAOL. oK for late model vehicles but not for small gas engines.
Let's not forget that the condensation process begins not in your fuel tank or gas can but in the underground tanks at the gas station. When they get a truck delivery, it stirs up all the junk in their tanks; the next few customers get it.
This is not the problem it used to be. Fuel filters at stations are much better than they were 30 yrs ago.
Just as an anecdote, I had a Ford 3000 diesel tractor that blew the radiator in 2006. I had plenty of tractors and little time, so I didn't get around to fixing it for 16 years. When I retired I tackled that job. The engine had set for 16 years without moving, barely even touched. I changed the oil, put a new battery in it, and it started up the first try. Same diesel fuel that had been in it when I parked it. The fuel tank had been filled when I parked it. Take that for what it's worth.
I have a tractor with a diesel engine. I love this about diesel, and I love that the engine will likely last 1000's of hours. I wish my riding mower was diesel, but it's a good machine, so I can't justify spending $15K+ to replace it.
Have no illusions about new diesel fuel lasting like it used to. The petroleum refining industry has greatly reduced the Sulphur content and is now gradually adding "bio diesel" to the regular diesel. Basically, it's being thinned 5% with cooking oil products.
Bio diesel is more suspectable to cold weather gel formation. It is systematically killing of older mechanical injection pump systems.
I learned a hard lesson on my 1975 JD 310 TLB because I ran the newer diesel fuel and did not use any kind of lubricity additive. I sheared the injector pump drive shaft due to the rotor head locking. It was all due to the newer diesel and low lubricity. A 3-cylinder injection pump is not cheap to have rebuilt.
There is nothing special about AG diesel except red dye being added to identify it for tax exemption purposes. There are lots of rumors spread by uninformed folks who think it is better fuel.
Of course, in the past year the price of diesel has shot up in many areas of the country.
I have a push mower I bought new in 1991. It gets an oil change and air filter cleaning every year. I check change the spark plug every 10 years or so. never had any problems with it. Starts on one or two pulls every time, but it is kept in a secure garden shed. leaving any motorized yard equipment outside in the weather cause condensation and water in the carb and the crank case. Condensation forms on the inside of containers on the bare walls, not below the liquid line, so keep them full. Don't worry about bad gas over one winter. 10% lead-free gasoline is great. Any moisture that does form will be absorbed in the alcohol and burned when the engine is run, Leaving the equipment outside exposes the engine to moister air for condensation and also direct water penetration through the gas cap vent hole. Yes it will!. Water can penetrate the tiniest openings. All airplanes have fuel tank water drains under each fuel tank to be drained during pre-flight on every flight. You would be surprised how much water can get into a fuel tank during a rain!. Look in the tank with a flashlight. If you can see water bubbles on the tank bottom, you can close the tank valve, disconnect the fuel line from the carb, and drain the tank into a can
