coffeesnob
- Dec 2, 2015
- 10
B&S Model 40000 Intek. The fuel filter is empty after sitting between mowings. I can wiggle the filter a minute or so and the filter fills up as normal I don't quite understand that But anyways to get the engine started I have to remove the air filter and and spray a bit of starting fluid then it will start and run fine. Is this the fuel pump. Mower is about 16 years old.
