bwdbrn1
I picked up a couple of mowers the other day for a good price. Two Honda HRM215s. One has a two speed transmission, and the other a hydrostatic. Guy was giving them up because they had issues he didn't want to deal with. Both mowers have the GXV140 engine. Along with them came a third GXV140 "parts" engine the guy said had a knocking rod.
Long story short, I couldn't get the blade holder off of the shaft, and it had to come off to get the engine apart to see what was going on inside. Anyway, I took it to a guy I worked for and had him cut the blade holder off with his acetylene torch. Well, in the process he managed to cut half of the p.t.o. end of the shaft off, obviously making the crankshaft useless in the process.
Once I got inside, I found the connecting rod bolts had loosened up and backed out nearly 1/2", and the bearing surfaces of the con rod were pretty messed up.
My question then, is this engine worth the time, effort and money it would take to replace the stuff needed to get it running again? It's a Honda GXV140, which is one of their commercial grade engines.
