Mad Mackie
- Jul 11, 2011
- 50
- 1,851
Hi Troops,
The intermittent cranking problem on my Tiger Cub got worse today as I was servicing it so I got into it with a colored wiring diagram that I downloaded from the Scag site. Nice to have a color coded diagram!!! I removed the control panel from the left hand fuel tank and beginning at the starter solenoid started checking for power with a clip on test light. I decided to disconnect each connector and clean it and the engine harness connector was the problem. Now the engine cranks over every time, and I finished the 50 HR service but didn't replace the blades yet as I still have a few customers that need the spring cleanup done. I also serviced several other pieces of equipment particularly my wood chipper which needed new blades and an oil change.
Mad Mackie in CT:biggrin::laughing:
