Interlock question
It's not DC as we think of it, nor AC. Everytime the magnet passes in front, it causes a magnetic field to form in the ignition coil primary. When the magnet passes, the field collapses causing current to flow in the primary. The primary current causes current to flow in the secondary (not sure of the voltage multiplication, probably at least 100:1) which causes a spark to flow across the spark plug terminals. While this occurs, the primary voltage goes from zero, to perhaps a few hundred volts, then back to zero as the field collapses. The voltage measured would be more AC like than DC, but without any negative component. On an oscope, this will likely show as a very noisy square wave (I'm guessing, haven't hooked mine up yet). The frequency would vary with the motor RPM, which is why I say it's almost AC. The trick would be to convert that noisy square wave to DC to run a safety switching circuit. What I'd like to know is the method the interlock uses to convert that square wave to DC. I'm supposing a cap diode and resistor would do trick, but I was hoping someone here has already figured that part out...
If you turn your flywheel to TDC during the ignition cycle, you'll see the magnet has already moved past the center of the ignition coil - this is how simple engines are timed.
Hi Georgia Dave,
I have only seen inline diodes for each coil used on the primary kill wire of most V-twin engines. It prevents primary "kill wire" discharge into each of the opposing coils.
I'm not sure about the idea of feeding coil "flyback" voltage back into an interlock device. As you say it would be a noisy square wave, or just a bunch of hash spikes.
I am not certain this or any interlock device is meant to be powered, it is simply a ground signal junction for all of the safety switches to meet at.
I have such an interlock (small version) on an old 1980's Snapper (no-electric start and no battery or lights) and all it does is ground the coil if the deck engage switch is in the on position or the key is switched to off. With both switches in their proper (start) position, it will allow the coil to work, and the engine can be started with the pull rope. Otherwise, a person could pull on the rope until they are blue in the face.
Lawnmower (magnetic induction) coils do not work quite the same as conventional old school 2-wire 12V automotive coils.
According to the diagram the key switch has its "master" ground, and the interlock has its own ground for the series of safety switches. The way I read it, each switch has to be in the correct open or closed position for the interlock to do its job.
In this case an Ohm meter would be used to verify the switches agree with the diagram legend at the top.
Looking at the wiring diagram, I don't see how it's possible that the module is not powered. Otherwise, why a 'module' in the first place, it has to be active (ie, powered), not passive, or it would have no value at all. For example, no non-mechanical switch can be thrown without power, thus it has to be powered by the primary feeding back to the module.
Take a look at the wiring diagram for either 988088 or 988089. These show the switch positions in the safety position. Look at the transmission switch (NC) and PTO switch (NO). Someone please explain to me how the engine can be started, and immediately stall when the transmission switch is in the open position and the bale or handle switch is left in the start/default position, without some form of 'electronic' switching in the module. Simply opening the transmission switch alone can't possibly signal to the module that the switch is open because the PTO is open.
Feel like I'm beating a dead horse, but appreciate the thoughts. Show me a diagram of how you think a passive (non-powered) module can control the primary grounding based on these schematics. If it's passive, it can only consist of wires, so please show me the wiring diagram internal to the module, it's not possible in any way I can imagine.
Many thanks!
Many thanks!
The key word I think is interlock. The word "module" is just a technical descriptor for circuit meeting place. It is where all of the safety switches meet.
It is a ground side only system, no "positive" power needed. Technically if any of the switches are not in the correct position, the coil is being grounded and prevent running.
To narrow down the running issue disconnect the coil "kill" wire and see if the engine will run normal. If not, the problem is on the engine side. If it runs well, then there is one of the "ground safety" switches at fault.
That is not to say the interlock cannot still have an issue, but it is a matter of narrowing down where the fault exactly is.
Don't forget a worn ignition key ground switch can also be at fault in the circuit.
So, if all the switches meet up in the module, then it's simply a wire, or other passive components, such as resistors, caps, etc.
Please, someone show me a diagram of those wires and passive components - I would love to be schooled on how that can work.
I'm not trying to be an @ss here - I truly want to know how any group of wires or passive components, no matter how connected, and make that circuit work. Saying it's so is not the same as showing a diagram of how it works.
My mower works fine, but no safeties. Every switch and wire has been verified, therefore it must be the module. If the module is simply a passive component, then there must be a way to add a wire here and there to bypass it. Show me a schematic, and it will all become clear.
Thanks again!
Thanks again!
Without knowing the internals of the interlock module, that is a wild guess on anyone's part. I cannot advise bypassing any safety device.
As noted in my OP, I'm not interested in bypassing, I'm interested in knowing the internal circuitry of the bypass. I will purchase an interlock, but my curiosity leads me to want to understand how it works. As noted, it appears to me that the device cannot operate passively, so again, being curious, I want to know how it's being powered from the primary.
I'm not asking for advice in how to bypass it, remove it, or do without it. My hope was someone on this forum had intimate electrical knowledge of the interlock unit itself.
Enough for now, appreciate the time!
Very few of us have ever seen one of these units in the first place (doubt even a Gravely has seen very often either) and then it would take someone with initiative to simple pull the circuit board out the interlock module housing. If it is like another OEM one I did pull out several years ago it is so simple it wasn't funny. I wish had took the time to record the info about it but I didn't even think of doing at the time as I wasn't running my own forum at the time and had serious family health problem that require a lot more of my attention at the time. If I remember correctly it is just a printed circuit with a couple jumpers and one lead that is a false lead, no magic components.
But since you willing to replace it there is little harm in taking the module apart for a look see. I would do it here if I had one in hand but I don't and have no reason to buy one currently. Besides I would most like start hard re-wiring once I knew how it was setup to keep costs down like I do with the JD ECUs on the Z800 and Z900 series ZTRs.
The interlock is not powered in any way. It is simply and interrupt device
I have just resurrected a Gravely 150 PRO - this is a recoil, not battery start engine. Can anyone tell me or give me a functional schematic of an interlock module for a non-battery powered engine. I understand that the interlock is powered from the ignition coil primary, but I've looked and looked, and can't find any documentation for any module that runs from the primary side of the coil. The interlock is bad, I hate bypassing it, but I also hate that the cost for the interlock is a bit higher than I want to spend (just shy of $200). I have quite a bit of experience with circuit design, but I don't know much about the voltage(s) on the primary side. I suppose I can dig out my o-scope and see for myself, but if anyone here has knowledge regarding this, or an example circuit, I would sincerely appreciate it !
Worst case, I'll buy the interlock, but I'd have a lot more fun building my own...
Here is the whole manual..
The late 1980's Snapper has/had a module that required the shift/gear lever be in neutral in order to enable the ignition. There is no seat occupancy switch, and, it's been over 20 years, it may have had a blade release cutout switch also.
It was not powered by the battery. In Neutral and with the blade dis-engaged, it would allow spark generation. I figured it must use part of the generator circuit to make a transistor conduct(?) before it would generate spark. I got tired of it being finicky, working fine and then not working at all, with me grinding down the battery, or in worse case, wearing myself out pulling the starter rope. A CV14 is hard enough to pull over that I decided it being disconnected was not a safety problem as I would be the only operator. A replacement was available, but 1)it added complexity and un-reliability, and 2)it was not reasonably priced.
The original replacement(exact) has been superseded to another box, containing who knows what, and it has not become more affordable. It is staying on the vendor shelf as far as I am concerned.
I did not take it apart, but figure it has to be a very simple circuit that grounds the ignition when the switch(es) are not in proper position. It really is kind of worthless, IMO.
It is inside a black plastic box, and might be destroyed if an attempt was made to examine the actual circuit.
I really just got tired of it killing the engine now and again while in use, and being very difficult to get started.
tom
