Teds
- Jan 14, 2017
- 82
Keep in mind while fuel stabilizers or preservatives work to extend the "shelf life" of gasoline, they don't do anything to allow the use of ethanol fuels. One reason is because they absorb water, also they attack rubber parts in the fuel system. Another is that the fuel mixture will run quite a bit leaner, all things being equal. This can be compensated for by adjustment of the "altitude" needle but lots of folks wouldn't know what it is much less how to adjust it. So LawnBoy has always cautioned against its use, in their service manual, as shown here:
"GASOLINE - Use automotive regular grade with a minimum of 89 pump octane, “No-Lead” or “lead free” gasoline of 86 pump octane is satisfactory if owner wishes to use it. DO NOT USE GASOHOL OR OTHER GASOLINES THAT CONTAIN ETHANOL OR METHANOL."
http://www.pure-gas.org
This website maintains a registry for all 50 states, of locations that offer gasoline without ethanol. This is where the fuel stabilizers come in handy. If it's inconvenient to obtain, purchase 5 or 10 gallons and treat. For most residential homeowners 5 gallons should get through a season of lawnmowing and maybe sno-blowing.
