I have a Troy Bilt LT-2146 with a Briggs Intek 21hp twin (Model 407777). The battery is not charging - it is not receiving a charging voltage, even at full throttle. I checked all fuses and then suspected the voltage regulator was bad, as it is a common problem. I looked at numerous videos about testing the regulator, BUT, I looked and looked all over the engine (including taking the shroud off) and I can't find anything that looks like a voltage regulator! In all the videos, it is usually bolted on the side of most Briggs engines and quite accessible. I did locate a wiring harness and probed it and found a 35VAC output, so looks like the stator/alternator is working. However, I could never find a wire with a DC voltage above the battery's resting voltage (with the engine running full throttle), so I do suspect a bad regulator. There are some wires wires from this harness (next to oil dipstick tube on right rear of engine) that appear to go up under the flywheel. On this particular engine, is it possible the voltage regulator is on top of the engine under the flywheel? Like I said, I've looked over the entire engine and can't find it elsewhere - seems incredible one would have to pull the flywheel to change the voltage regulator!
Where the heck is that regulator???
