Lawn mower has a B&S Intek V-twin 19HP
Model 407777
Type 0137 E1
Code 980422YG
Does anyone know what the spec is for the pushrod length?
It overheated, valve guide slipped, bent one or more pushrods. I got the pushrod part #s, 690981 (steel, exhaust), and 690982 (aluminum, intake).
I was sent a generic kit labeled CT160 (or CTM160, something like that), which is supposed to be the above two part #s but compared to a bent steel exhaust rod that was pulled, the new pushrods look about 1.5mm shorter.
I checked the engine service manual # 273521 and it doesn't spec the pushrod length.
Is there an acceptable range of length that can be adjusted for, is something 1.5mm shorter likely to work okay? I'd just throw it in and try to adjust it but the mower is at my mother's place and I'd like to have viable parts when I get there.
Model 407777
Type 0137 E1
Code 980422YG
