:welcome:
There is a diode between the two cut out wires.
Disconnect them there and try again.
Problem goes away , replace the diode.
It is there to stop the coils backfeeding a signal down the kill wires and interfearing with each other.
to stop the engine, earth both wires to the block.
A you will be running without the cowel in place keep the time short to avoid overheating.
