- Nov 29, 2014
- 64
- 24,647
Congratulations
Not quite sure what your description is but check that the carb is not still leaking
Because I am belts braces and rope man I like to fit a tap in the fuel line closest to the tank so I can shut off the fuel without having to pinch the fuel lines and of course you can turn the fuel off when not is use..
You really need to change the oil twice and change the filter ( if fitted ) on the second change.
