Intek 18 hp OHV- #31E777 0443 E1. Loud popping at higher RPM, under load, or hitting bumps(roots, etc.) Video under 1st Reply. Thanks for any input.
Scrubcadet10
Moderator
Staff member
  • / Intek 18 hp OHV- #31E777 0443 E1. Loud popping at higher RPM, under load, or hitting bumps(roots, etc.) Video under 1st Reply. Thanks for any input.
Fish
Yeah, the solenoid acts as the nut. Just take a 1/2 inch wrench an loosen it slightly, the just unscrew it a bit. Try and catch what dribbles out to look at it, that water can be a pain to fully get out of the system, but it does sink and sit in the bottom of things. Which is why it acts up when turning sharply, bouncing, etc., then a tiny bit of water sloshes up into the engine.
Fish
You may have to get a cheapo wrench and grind it a little thinner to get on the flat surfaces of the solenoid.
Fish
just unplug the wires before turning the solenoid.
Klyonh
Klyonh
The only thing I wonder is why does it do it every time I throttle all the way up also? But doesnt stop until I throttle back down?
Klyonh
I cant run at full throttle.
Klyonh
Tried it and it still does it. Noticed small crack in upper gas tank though during the process and ordered a new one. But did what you said and it still pops like in the video at higher rpm and going up hill with blades engaged.
Fish
New air filter?
Klyonh
