Mr Fixit.
- May 28, 2024
- 7
I have a ZTR mower that had a failed Kohler engine. Replaced it with Vanguard EFI 28 hp. Changed the pin orientation of the Molex connector on the ZTR to match the Vanguard motor. I have no safety switch issues that would stop fuel pump from being energized. The engine cranks, I have spark, but no start.
The vacuum operated fuel pump is working. I have fuel at the pressure test port, but no high pressure. The high pressure fuel pump is not receiving the negative from the ECM for the pump to run. I do have the positive from the MPR when the switch is turned to the run position.
I know a safety switch in the wrong position stops starting by way of the ECM not sending negative to the fuel pump, but I do not have this problem. I do not know what other conditions would cause this situation.
I have read through the repair manual and made many voltage checks coming to the ECM. All inputs I checked have been good.
I have searched for some kind of logic flow chart or something to become more familiar with how the system works as a whole.
A new engine should not have this issue.
Any suggestions would be greatly appreciated.
